Comer K-80
wall
Portugal
I have a brand new kart with a Comer K-80, never used and a few years old. The thing started after many attempts and runs perfectly but dies as soon as I release the throttle and I noticed the carb was leaking gas when pulling the starter. Maybe I just put too much oil in the mix, or should I just let it warm up?
wall
Portugal
I adjusted the idling screw until the clutch starts engaging (with the rear axle in the air) and it "almost doesn't die". I guess the mix had too much oil, I'll keep this thread updated next time I refill the tank.
qtband
St. Louis, MO
If it has been sitting awhile, I'd get an $8 carb kit & rebuild the carb. Those diaphram carbs don't like to sit with gas in them.
wall
Portugal
The engine was brand new, my initial problem was a too much oil in the mix.
The carb is a Tillotson HL-166C and is still leaking into the lower part of the air filter mesh.
Any tips on engine break-in? I've only ran it moderately for aprox. 20-30min, that thing is a beast.
wall
Portugal
And I still have no idea what is the correct number of turns for the high and low speed jet screws.
wall
Portugal
I adjusted the jets according to mcrengines and it is still dying when idling. This time I know it isn't too much oil because I measured exactly 5%. I tried messing with the low jet but that didn't seem to make a difference. Where should I be looking for problems?
wall
Portugal
Now I adjusted according to the Tillotson manual and it idles fine but dies when I release the throttle after driving it fast. Is it too lean now?
It is also smoking a lot less.
