science5252
- Messages
- 19
- Reaction score
- 0
I have a honda 20hp motor that has a 1in. x 2 29/32in. shaft. Does anyone know of a clutch that is stong enough and will fit the shaft?
I have a honda 20hp motor that has a 1in. x 2 29/32in. shaft. Does anyone know of a clutch that is stong enough and will fit the shaft?![]()
I am building a yard cart with an old 8hp Briggs.. it has a 1 inch shaft. I TOO NEED A CLUTCH
I found one for 76 bux shipped.. I been looking since FRIDAY
There's also shifter karts, these usualy have a motor cycle engine with a built in 5 or 6 speed transmission like this one:http://www.rc-trucks.org/racing-go-karts-vortex.jpg
Marvinsanti:
How did you mount those pillow block bearings on a round tube frame?
They can be lots, they can be dirt cheap. I recently bought a whole motorcycle for 40 dollars, all it needed was a coil and it runs great, the total cost of the bike was around 70 including an oil change. This motorcycle engine is going in my kart (under build log, kz400 shifter kart project). Putting a transmission like this on another engine is highly not worth it. For the most part your going to have to buy the whole engine to get the transmission, split the cases, take the engine part out, run a straight shaft with where the crank shaft was, so its really not worth it since you could have just left the motorcycle engine intact.
from the picture it looks like a hose clamp! LOL Hope not:arf:
