Clutch
Kelly
Ky
just bought Murray GT60401X492 6.0 Tecumseh but if you start it has to have someone in seat holding brake. Is this normal? Also engine is surging the cart is a few yrs. old but only ran a total of 1 hour by previous owner. :huh:
t0x1k
Vroom
South, NJ
what kind of clutch? CVT or centrifugal?
CVT belt is too tight, centrifugal, the springs are bad, the engine surging is engaging the clutch, could be a lot of things.
mike75925
thinker and tinkerer
Alto, tx
try turning the idle speed down, if that doesn't work, take the clutch off and clean it. if a regular clutch, you will need a clip ring plier. if you don't have one, a jewelers flat-head or a small nail will assist you easily enough. the surging may be trash or water in the carburetor, or a hanging clutch.
Kelly
Ky
What is cvt or centrifugal? Im new at this. Should i clean carb? Going to try to clean out sediment bowl first. Thanks
Kaptain Krunch
Pro Junk Collector
vermont
Cleaning the carb could help, does the chain go directly from the clutch to axle, or is there a belt too? If there is a belt its most likely a CVT.
