Clutch
MikL99
Ohio
So i'm looking for a bit of advise on how to proceed. I bought this clutch:
http://www.amazon.com/gp/product/B00FQQ2BHS/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Now the kart has been driven about 3 or 4 days worth and there seems to be a problem with the clutch. Out of no where (while idle) the clutch will make a loud noise and engage and move the kart. You hit the throttle and it fixes it and goes back to normal.
So the question is did i go cheap on the clutch and it just couldn't handle my son's style of driving. I know these clutches like to go full throttle and i know my son just lacks the experience with ride go karts and tends to let go of the throttle too much.
I know i can take the clutch apart but i didn't know if i would be able to put it back together. Now maybe if i buy a new one i'll tend to be more brave and take the old one apart.
Is there a clutch you recommend that i should start out with that might handle my son's driving a bit better?
Thanks again guys for all your help.
First off, what is the gearing that you have on your kart? You might find that it is too high, and the clutch just couldnt handle it. Have you been lubricating the clutch or not?
MikL99
Ohio
still new to all this so i don't know my Gear Ratio yet. I can find this in a couple hours when i go home from lunch. (i just have to count the driven sproket Teeth so i can do the math).
As far as lubricating i have not. Again i'm learning as i go. I'm not even sure what to use for lubrication and where to lubricate.
Ok, after googling it does sound like it needs lubricated. From what i read i should be able to add some 10w30 on the bushing. Now this is where i'm unsure. Does this mean i have to take the Bolt off the end so i can get oil on the bushing? I'll have to look at lunch. I've read this is where the snap ring is at the end.
Count you axle sprocket as well as your clutch sprocket teeth. Post here. Do you have a Torque Converter or a centrifugal clutch? A centrifugal clutch is lubricated like in the diagram below.
Oh....and what is the diameter of your rear tyres?
let us know the diameter of the driven wheels and the approximate weight of the kart as well.
and if you know the power of your engine that would help as well ;)
the clutch should be lubed (the bronze bushing) before you go and then after every couple of hours of driving (3-4hrs iirc)
but if your son is too carefull on the throttle it might be slipping all the time, and that will burn it out rendering it useless after a while..
if you remove the circlip from the sprocket you can take off the sprocket and bell;
that also lets you inspect the shoes..
if they're blued it got too hot already.
teach your son and (to help him get used to driving speeds) lower the gear ratio
add a bigger sprocket to the axle so that the kart maxes out at a lower top speed.
(and the clutch is fully engaged at a lower top speed as well ;))
But first let us know the numbers ;)
We love pictures btw.. so a pic of your kart is very welcome too :D
MikL99
Ohio
alright. Here i go.
I believe it is 5:1 ratio. (60t/12t)
7hp Predator 212cc engine
back tires 145/70-6
Front tires 4.10/3.15-4
Kart is a Manco American Express
Stupid chain is giving me fits. I don't know how or why but last night when i put that chain on it was too tight. (did not drive it). Today at lunch it seems way to loose now. I have no idea why.
Hope this helps.
Poboy kartman
Senior Moments Member
White Settlement Texas
Well......this is interesting. .....It looks like all in the world to me that that axle is split at that sprocket and the 2 shafts are not aligned.....
Is this possible? ?????
firemanjim
Just kartin' around....
Houston Texas
Nope, it's a one piece axle..... That's a camera trick..... The diameter of the shaft on the left is throwing you off more than likely.... Between the sprocket and brake is a spacer.....
EDIT on closer look, his doesn't have a spacer, it's just dirty..... LoL My nephews has a spacer .....
very nice kart indeed...
I can't tell it's weight; so that'll be a guess (I guess 275 lb with an adult rider)
wheels are roughly 14" in diameter
and the 212 predator is 6.5hp IIRC (even the hemi)
so...
KartInfo by kartcalc.net:
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]RW diameter[/I]: [B] 14 in | 35.56 cm[/B]
[I]Total weight[/I]: [B] 275.58 lbs | 125 kg[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Original HP[/I]: [B] 6.5[/B]
[I]Asummed HP[/I]: [B] ~6.5[/B]
[I]Torque[/I]: [B] 9.48 ft lbf | 12.86 Nm[/B]
[I]RPM[/I]: [B] 3600[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B]
[INDENT][I]Final ratio[/I]: [B] 5:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Max Wheel Torque[/I]: [B] 47.43 ft lbf | 64.3 Nm[/B]
[I]Acceleration[/I]: [B] 9.48 ft/s² | 2.89 m/s²[/B]
[I]Top Speed[/I]: [B] 29.99 mph | 48.26 km/h[/B]
[/INDENT]
[B][U]PROBLEMS[/U][/B]
[INDENT][I]You might burn your clutch/belt![/I]
[I]Gear ratio too high![/I]
[I]Suggested final ratio[/I]: [B] at least 7.7:1[/B]
[/INDENT]
[/FONT]
if it's 220 lbs you can get a higher gear ratio of about 6.8:1
so that's either a 92 T sprocket (19.5 mph) or a 82 T sprocket (22 mph) on the back.
that would release all the stress off the clutch ..
BUT the tyres are stock on some AmEx, and the sprocket is stock on OTHERS..
your kart is geared for 4.10x3.50x5 slicks (12" dia) with 5:1
and the gearing for 140/70x6 knobbies is 6:1 originally (72T axle sprocket)
So personally I'd start with that 6:1 ratio (you'd need a bit more chain 87 links or so compared to the 79 you should have now)
that should keep the clutch alive as long as your kids are driving
(~172 lbs total weight)
and if you take it for a run, just hit the throttle and it shouldn't be all that bad every now and then (if you do not feather the throttle ;))
MikL99
Ohio
Ok. I think I understand. I need to get a 72t sprocket. Right? I found the part online for 17 bucks I believe. Or can I use some sort of universal?
Also Axle is not bent. No idea with the chain hanging. I can't move the engine because it is too big and hits the seat. Just no room. So it's either add a plate or cut and move the engine mount. Right now chain will be either too long or too small without some sort of manipulation to the engine mount.
Also yes everything is dirty and rusty and paint scuffed. First part of this build was to get everything working. Then comes the sanding and painting.
yes a 72T sprocket.. if you buy at ombwarehouse for example (as on many other shops online)
you can find what's called a half-link or offset-link for your #35 chain. ($1 ;))
that is exactly what you think it is.. one roller per link (with offset linkplates)
to get that intermediate length where a chain is too short or too long.
I'd recommend split sprockets for your sprocket hub, that way you can (if you need) change the sprocket without having to remove the axle.
if you cannot get the chain to fit with an offset link for example, you could also add a tooth to the sprocket to allow for a tiny bit longer chain ;)
Poboy kartman
I think I got this one figured out........I see washers on the floor.....I'll bet some squirrel snuck in in the middle of the night and stole your nuts!!!!!!
I haven't got to test them yet, but I bought some of those exact ones from omb myself...
and I feel confident about them ;)
(still cheaper than to buy them locally for some odd reason)
Do not forget the offset link .. you'd want one sooner or later ;)
