Clutch Won't Disengage
PBracer
Recreational Mechanic
Hudson Valley, NY
Hi everybody I have a 2001 Briggs and Stratton 6hp Intek 190 on an old Murray go kart I have been restoring. I just bought a brand new 10 tooth clutch from Northern tool and put it on the go kart today. when I start up the go kart, however, the clutch does not disengage and the kart takes off immediately, in idle, on me. the brakes are able to stop it but if I take my foot off the brake it starts going 25 MPH without me even touching the gas. The throttle cable is plenty tight and has full movement range, and the chain is tight but still has a reasonable amount of play. I have tried this on all governor settings to no avail and have adjusted the idle screw multiple times with little to no result. The clutch does not smoke when used at all and I just rebuilt the entire carb. This kart is currently very dangerous to operate, does anyone have any ideas to why this clutch will not disengage in idle? :confused:
Axx3d
MN
Does it do it with no throttle cable hooked up?
As far as adjusting the idle having no effect.. it doesnt drop the idle when you screw it out? or rais it when you screw it in?
When you rebuilt/cleaned the carb did you get air/gas screw set correctly to begin with?
25 mph with no throttle input, certainly seems like a carb/throttle/governor issue to me. First, the throttle cable should have some free play or slack at idle. Make sure the throttle arm that the cable attaches to, moves freely, and has a return spring on it. Be sure tgat it automatically and quickly returns to idke when you rekease the pedal. Temporarily disconnecting the throttle cable is a good troubleshooting step. With the chain off, start and warm the engine, and adjust the idle speed down to where it should be. If all this gets you nowhere, the governor may be out of adjustment, or defective. Being a new engine, I'd make a warranty claim at that point.
PBracer
Hudson Valley, NY
Hi everyone, thanks for the advice but I don't think this is a throttle/governor issue for a couple reasons. the throttle cable has plenty of slack and though the idle screw has some effect to the idle it is not nearly enough. also I manually lowered the idle today to about 300 rpm and the clutch still would not disengage. Also this clutch does not just engage on run, it will also engage on every choke setting save for choke itself.
ML-TOYS
long island, new york
Remove the chain and see if the outer clutch bell free spins with motor off.
If so then remove clutch and take pics of the internals of it.
