Brandon1023
needs an oil change
finally planning on doing the axle conversion on my go kart and i was curious as to how much it'd all cost. one major variable is whether or not i should keep my clutch, or buy a torque convertor despite the price. here's my situation.
- 15 x 6 - 6.00 tires
- 13 HP Predator 420 cc
- Single drive tire
- 60 tooth axle gear
- 14 tooth clutch sprocket
the point of this thread is for someone to hopefully clear up my confusion about torque convertors/jackshafts. right now my go kart is at a 4.28:1 ratio. does a torque convertor cycle through various ratios depending on the load? (such as going up a hill) obviously the V in CVT stands for variable, so im guessing. is a torque convertor going to switch to low ratios when taking off, and then cycle through ratios until it gets higher? and what causes belts to burn up? obviously slipping.. but there's gotta be more to it. next up.. why the jackshaft? i know it's a reduction gear, but why doesnt the torque convertor handle that?
i know that cent force will cause the driver, driven, or both (cant remember..) to open and close based on rpm, right? how does this help? allows the belt to slip? im confused here.
- Single drive tire
