clutch stuck on engine.
Jblankster
Illinois
well i feel very dumb after this.
we have this 8 horse engine, old, sitting outside etc. that i finally get running great, decide to swap engines, well to make a long story short. the crankshft end where the clutch goes was rusted a bit, so i was able to get the clutch on with a hammer (first mistake) and well after the clutch was borked to hell and now dosent spin, so i need to get this clutch off to put a new one on.
the question is how. i have NO IDEA how to get it off.
please help. or this engine has become nothing more than a showpiece in my garage LOL
brendonv
Australia, Perth
Put a bunch of spanners behind it, as many as u can fit then get a big flat head screwdriver and smack it between the gap. That will push it out a bit more then fit another spanner in and repeat. Thats how i got my sprocket off when it was stuck to my axle, works great. U can also use a big chizel instead of a flat head if the gaps to small for another spanner but to big for the flat head. I hope that helps. Ohh and u can fix it, all u did was make the end of the clutch burr and push in the C clip on there which holds the drum on. Once u get it off just take the c clip off and file down the burr. I no this since i did it my first time too. After that i took the clutch off, fixed it then ran the engine, held sandpaper on the shaft until it was shiny and the clutch fit on nicely. Also wen u put the clutch on, put a thin layer of grease on the shaft, this stops it rusting on.
brendonv
Australia, Perth
thanks! i will try the above 2 ideas first. i just hope i can get the **** thing off
When theres a will theres a way. XD U will get it off, just one tip. NO HAMMERS!! There bad and do more harm then good. Well i mean u can use it to smack the flat head in but dont bash at the clutch, it hurts the clutch but more importantly the shaft.
lemegacool
got boost? :)
quebec canada
the jaw puller would be the best option... if the puller only doesnt work do this: put penetrating oil on the crank and let it get inside, then install the puller on the clutch, plug a impact wrench on the puller. ,now you have two choice. 1 you try to pull it or you take a torch and heat it (quickly, the crank must keep cold otherwise it will expand) then impact it out
Kaptain Krunch
Pro Junk Collector
vermont
Heating warps the shaft which is bad. I would try everything else before trying to apply heat to it.
Yea if you hold the torch there for a ****in day, if your just heating up the outside of the pulley a bit, its fine, The point is to not get the crank hot anyways.
Jblankster
Illinois
i got it off fine, but in like 8 pieces. the clutch was crapped to hell so we pulled the clutch off the watchamacallit, then pulled the shaft off the engines shaft.
thank god for PB blaster.
squat251
another idea, incase anyone else gets stuck like this, is put on the puller, tighten the balls out of it, and then give it one or two good taps with a large hammer (the bolt on the puller) this works great for flywheels too, it wiggles the shaft just a wee bit and hopefully breaks the friction just enough for the part to pop off. and be warned its kinda scary the first time you do it, normally a loud bang and some rattling.
Jblankster
Illinois
i remove my flywheels with a screw driver and a hammer. works like magic. im not gonna go into it since its how everyone does
now, how do i know what type of chain the clutch was? because i need to order another one, and idk what chain type it is
oscaryu1
bump, because i still dont know how to find out wat chain type it is :(
Ya want picures of a #35 and #41 clutch? Compare then lol.
And just so you know, a trick I use on rusty crankshafts:
Start the engine up, get a piece of sandpaper, and left the crankshaft de-rustify itself.
Jblankster
Illinois
okay im going to get all this done today. i need to order this **** clutch and RE clean the engine. it like sucked a diper or something and the fuel filter keeps getting clogged lol
