Uhm, WOW, they got back to me really fast!
Here's what he said:
Quote: If the spring color is silver you are correct it starts to tick around 2,200 and is LOCKED when it gets to 2,400rpm. There are two stronger springs.
So yes, our clutches engage at 2200 and lock at 2400 RPM.
Thanks for the verification.
Odd, but if Jim says so I must have misunderstood the denomination earlier for what he was explaining..
(or they changed the spring in the last decade to not have to deal with issues on high speed idling engines like the predator)
older Hondas, and essentially all brand engines idle at 1400 rpms
Mine came with a blue spring btw.. (and it was labelled 1800 on the orderform)
Anyways.. while that makes room for a slightly lower engagement speed (weaker) spring;
it certainly wouldn't help with the issue..
the predator idles like crap at low speeds because it doesn't have any power down there..
so acceleration wouldn't improve if the spring woul dengage earlier..
chances are it'd be worse in fact.
But what now is the blue spring still available or not?
a stronger spring is the exact opposite of a faster full locking clutch as explained above.
So swapping springs is still not going to help either way!
Especially if they -as the reply implies- only make two stronger springs now anyways
I mean frankly.. Jim makes you whatever you want.. if you just ask nicely
(that does include indicidually dialed in engagement speeds AND fancy toothcounts as long as they're viable (1" 8T #35 is NOT
PS thinking about it.. if you
never have good traction (always on wet grass or loose gravel) maybe a stronger spring would help... since the wheels can break traction with the initial jerk...
but as soon as you got grip you are likely to burn out the clutch at a higher engagement speed before you get up to speed in just a couple of runs.
