Clutch smoking
merganser
Ontario Canada
Hi guys i have been building my motorized track sled (will post some pics later after deer season) i was working on engine speed the clutch started smoking it probably smoked for a minute its brand new hillard heavy duty 1 " is it toast or did i just shorten its life.
Thanks Paul:cheers2:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Without more info or pics of the sled. It is hard to say.
I will tell you this much though. You are in luck because Hilliard sells replacement parts, so if the clutch shoes are fried you can get new shoes without buying a whole new clutch.
easy to tell.. if the bell is discoloured.. it's toast!
(both actually, the shoes and the drum; if the latter needs to be replaced I can't tell, chances are it's already oval by now.)
I smell bad gear ratios tbh.
Please provide us with all the sprocket counts on your build. Axle sprocket, jackshaft sprockets (if you have) etc. You say it is tracked, please post a pic
