clutch & shaft ?
polcat1p
My clutch dosent seem to fit on my new clone. I dont have my ole tecumshe, so i cant compare. If i slide my spacer and iner clutch on the shaft, there is only 1/2 left for the outer part of the clutch. Even if i put it on the bolt doent catch.
polcat1p
another ? i have is do you think this clutch will hold up? is a 6.5 clone with. it doesnt say what series is on the clutch
cam
billet flywheel
billet rod
14cc head
gov removed
flat top piston
filter and exhaust
polcat1p
any one know the size of the bolt? i bought 8mmx1.0 at home depot, and they thread in a few then bite.
thanks
gcarter95
Ottawa, Ontario
I think it is the 5/16-24. But bring the original bolt to HD with you - they have bolt sizers there that will allow you to be sure.
Blazkowiez
Kart Aficionado
Houston, Texas
All that is required for the main assembly with hub is at minimum 1/4" to hold it on, the main thing you need is a longer bolt. You will be fine, just make sure the back plates line up well.
solomon
ca
I know on the larger engines, i guess 7hp and up? they use 7/16-20, at least i think? And yea, why don't you bring the bolt you have with you? Will make life easier.
polcat1p
i did but the sizer a depot is so sloppy from everyone useing it. Thats how i came up with a 8mm bolt.
thanks guys
