Clutch set up?
Tilly212
Is 14 tooth clutch sprocket and 41 tooth for rear sprocket good for top speed, acceleration, both or neither?
Running it on stage 2 tillotson 212 hemi with .265 cam and no Gov and tct carb.
Do what McK said. ^
Casting aside other aspects, that gear ratio will (typically) get you a high top speed but dreadful acceleration; it will basically smoke your clutch to ruins before you even get a glimpse of that speed.
Maybe if you get some fast friends to push your kart to a running start while you floor it? :D
http://www.diygokarts.com/vb/showthread.php?t=26445
