clutch question???
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Ok since you are stuck on trying this I'll go with it.
In your idea I do want to ask you to think about one more thing.
The combo Clutch/Brake pedal. I have used these on Lawn tractors.
The problem I see especially since this is for kids and one being 5 yrs old (I think you said).
So first you let off the gas to slow down, then...
When you push the brake pedal the first thing that happens is the clutch releases and for a millisecond before the brake engages you are free wheeling.
This actually allows the vehicle to almost accelerate as you have lost the engine compression slowing the vehicle.
Then if a small child does not push the pedal hard enough you are now coasting, possibly faster not stopping or slowing.
Go karts are fun cause they are a little on the crazy out of control side, and things happen real fast. "Handles like a Go Kart"
When you need to jab the brakes you Need to jab the brakes... Like NOW!
Just a thought, and I only mention it thinking of the Children.
pRoFiT
Can't buy it?, build it!
California
LOL.
Now I want to try to make a manual shiftable trans using a standard pulley, a TC driven pulley, and an idler pulley on a lever.
Pull the lever to engage.
Pull a little harder to shift?
Spring connecting the idler pulley and the lever?
Finding the right spring might be tricky.
Challenges are fun. For testing purposes only?
Yes I DID READ why it won't work!!!
More GAB Less KISS!
LOL. Hmmmm????
Yes that sounds like fun waste of time! Maybe keep the TC intact and add an idler pulley transmission! Like the one shown in my perfectly beautiful drawing. :cheers2:
p.s. picked my TC up for ~$70 shipped. China clone.
p.p.s. hmm idler pulley. could of used that on my trike.....
edit: Another great idea. you could build cam action control for it too. so each pulley gets pressure from a cam. then you only need a linear gear shifter! Now i wish a had a bunch of pulleys laying around!
pRoFiT
California
oh yah liking this idea now.
You could grab an old variable speed drill press and use the innards of it. already setup with the pulleys and ratios. need some longer belts maybe but it could work!
then throw in a boat throttle control..... :auto: :wai: :roflol:
sid, we're just going to have to agree that we disagree.
i just looked at that driver to see if i could put a bolt through it and convert it to a regular pulley. i notice one of the castings with the
"shoes" (sorry, non-karter here) hooked to the pulley is broken. planned obsolescence strikes yet again.
sid, what is the average (best of worst, worst of best) life of a tc unit? all things considered. i'd guess the front half at the motor gets the most abuse?
i drew up a diagram this morning: imagine you push the brake and it engages the clutch, as you push down further you apply the brakes. both on one pedal, same as the old craftsman mower. not that complicated considering the tensioner can be positioned with plenty of room for travel. mild steel round stock could easily be fashioned to fit around the drive pulleys to keep the belt from jumping off.
lastly, there are several examples of a tensioner type belt system on various kart sites but i'll certainly share a pic or two when i get to it. i'm up to my elbows finishing a 62 vw meyers manx type dune buggy. put it on the road the other day. has to be ready for a car show this coming weekend. too much work, too little time.
chas
as all mechanical and moving parts lifespan heavily depends on maintenance and abuse...
I've seen 20+ year old TCs that have seen regular maintenance and work like a charm..
I've also seen some that seemed to be rather young and are in really bad condition.
A broken cam I've rarely ever seen (I think I remember seeing a total of three so far never a series30 though)
And some are just left to die and rust away for no other reason than a lazy owner.
But I also know that with a spoonfull of elbow grease some of those can be revived to fullest glory.
Nearly every single part is replaceable The part you're likely talking about comes with a new riveted moveable sheave...
http://www.mfgsupply.com/gomini/gom...gominiclutchtorq30drivenparts/219466a-w1.html
And it's DRIVEN <- N not R (driver is the part on the engine you lack.. that drives the belt.. the one part you have get's driven by said belt... hence the name ;))
Hmm personally I'd rather disengage the clutch with the brake pedal than engage it if it has to be the brake pedal for some reason.. but that's likely just a matter of preference here.
(personally I'd engage the clutch with the throttle pedal if I had to make a tensioner clutch)
But frankly I'd never make a tensioner clutch at all.. since yeah..
without a mower gearbox that only costs power for no reason.
Nevermind.. go on.
With what profit was describing, I could see it looking like a Lenco racing transmission...
chasgas
sid, 40$ more to go the tc way. agh. i would never have thought a tc drive would go for years.
safety, supervision and not much speed! but don't tell them...
all finished here.........
thanks sid and all...........................
chas
I had my 8hp dingo for 12 years when I sold it. It was always stored indoors and never put away dirty always washed and maintained. When I sold it it looked like new except for the seat which was wasted. For those 12 years it was used EVERY weekend winter, spring, summer and fall and while I was not driving it during the week my baby sister was. Still had the original clutches and was on it's 6th belt. This cart was driven hard and mudded even harder. Yea, I think we here have a little more experience than you do. :thumbsup:
chasgas
why? why take the time to type "we're more experienced than you"?
tearing someone down somehow lifts you up? we have a very limited amount of time on this earth, better spent in the light.
the only reason i started this thread is because i had no experience with kart drive-lines, specifically the i/2 of the tc setup (driv*en*) that i acquired.
unless someone has something to add that progresses this thread, speaking for myself, i think it's played out. look for some pics of my clutch in a month or so.
for those of you thinking of a transmission there's a very good thread on this site that addresses vertical engines and peerless transmissions. i'm all for fabricating but as sid points out, WHY REINVENT THE WHEEL or "it's better to copy success than to invent mediocrity".
peerless also makes an automatic and are quite affordable.
chas
Denny's post though paints a nice picture of what TCs do... they just work!
If taken care of they work as long and hard as the engine itself would.
And if geared correctly, the belts lasts for years as well.
I hope what he was trying to say was:
his TC has seen more road than yours.
I think I've already said, that
we as a community are able to easily outsmart every single individual of said community.
And now chas, since you are part of the community, you are Borg!
Welcome to the hive mind. :D
Knowledge not yet accessible to your node will be transfered upon request.
chasgas
sid, you sir set a great example and honestly, the community would be hard pressed to outsmart you.
i would bet about the same time the v belt and v pulley were invented somebody realized a tensioner on a spring was the best way to keep the v belt tight. not a clutch, simply a third pulley whose sole purpose was to keep the belt adjusted as the belts stretched. before the tensioner, when the belts slipped, an adjustment was required. imagine the time saved by not having to reset the placement of whatever piece of equipment was being used every time the belts needed tightening. the transition to clutch probably happened within days. KISS- keep it super simple. a pulley on a stick that has proven itself certainly since the industrial age.
i base set a 32/36 progressive dfav weber carburetor today, tuned it with an engine using an 009 distributor (non-vacuum) and she sounds "pretty good", this with factory jetting.
if you know what i'm talking about, putting a pulley on a stick, placing it in a pivotal position between two pulleys, adding a spring and hooking it to rod sounds well within my or most of your memberships wheelhouse!
i really have to change the subject: the owner of the kart i bought hardly used it and sold it to another guy. the bearings were setup on the rear axle also wheels, brake drum, sprocket. well, he had no torches/heat and decided to cut the axle into three pieces. really didn't help him as he couldn't remove any of the components. in his defense, this kart has been outside for years. it took me an hour to remove the locking nut and drive the axle piece out of the first wheel. heat, penetrating oil, bang with a 12 lb sledge. my press wouldn't touch it at 12 ton. the second wheel was worse. literally broke the spindle out of the front of the wheel. not for lack of heat i can assure you. if the wheel was valuable a better method would be to get a bucket of water and melt the axle out of the spindle a little at a time. if you take your time you can burn out the axle without scorching the spindle. this will plug your torch tip (your burning into a hole) and that's where the bucket comes in, burn a little, dip your torch in the water. the hot torch hitting water cleans out the slag (occasionally hit the oxygen a little when it's in the water). the first time you try it you'll probably scar the spindle but you won't ruin it if you go slow and easy. as you get deeper into the spindle you'll need to take a chisel and pic out the slag. burn, dip, pick until you go through or you remove enough material and the axle will drive out.
there's a wrecked kart at the local u-pull-it with what appears to be a complete rear axle. i gave it a quick look when i was looking for a kart.
it would have taken several hours straightening, steering parts were gone, so i decided at the time not to get it.
later,
chas
All I was trying to say is with proper maintenance a cvt will last a long time. I was not trying to rub anyone's nose in anything, Just relaying my experience. :surrender:
Poboy kartman
Senior Moments Member
White Settlement Texas
OK....How about you just SHUT UP ABOUT the stupid idler pulley already?
You have and continue to make ASSinine ASSumptions about this forum and it's membership.
Apparently, YOU are the one that didn't get the memo. You continue to spout off the graces of the bow and arrow to machine gun manufacturers.
What we tried to explain to you was akin to taking a 32 mpg car with a bad injector and instead of replacing it...converting it over to a carbureated , points and condenser 8 mpg POS.
It's not like we don't know about idler pulleys....it's WHAT YOU DON'T KNOW....and we don't need you to tell us....
BTW....I can remember exactly where I was and what I was doing when Neil Armstrong stepped on the moon....and JFK was assassinated....
chancer
&#596; &#613; &#592; u &#596; &#477; &#633;
COMFORT, TEXAS
I can remember when the Challenger exploded! 6th grade!
and My 1949 VW never had a belt tensioner.
I was in my grandparents living room watching CBS chanel 2 when Neil Armstrong landed and walked on the Moon. Gramps made me watch it all because it was such a historical day. :thumbsup:
Well chas.. thank you I guess..
but more important than being smart is being of help... I try my best.. all I can do.
Yes, well no... sure uhmm what I want to say is..
When the first transistors came out they were huge tubes drawing tons of power and it was state of the art...
when the first guy used etched silicone instead... let's make it short: You own a computer, right :D
No honestly, a tensioner pulley was for a long time the easiest way perhaps.. it was never the best..
the belt rubs by design when not tensioned.. that causes belt wear.. a minor issue if there are no real alternatives (like for vertical engines)
but if there are alternatives that cost about the same (I say about since a set of both TC pulleys can be had for 70 bucks on ebay currently) that require less work, provide a better result (and yes, the variable transmission part of the TC should not be underestimated)
I still personally do not quite understand why one would want to go with simple tensioner systems.. especially since there is absolutely NO benefit with that.
CVT (like the TC on a gokart would be better described as) are around since the 1940
on commercially available vehicles since the 1950 that is..
... that makes them almost 76 years old.. 66 if you only count the first sold Motobecane with Mobymatic.
So not really all that "new tech" at all ;)
here's a DKW Hobby motor with transmission (made in 1957) and that's a bit awkward looking but the very same principle as the TC we talk about here.
Again.. I'm not saying you should not make a tensioner system type of clutch,
all I'm saying is, that you can skip all that and be done with the setup of engine, clutch and transmission in about 30mins if you opt to go for a TC instead.
And since you said KISS.. let's take a quick look at the order of operation:
TC:
Add motor pulley,
add jackshaft pulley,
add belt. DONE
Tensioner:
add motor pulley,
add belt,
add belt catches to prevent belt from slipping off when untensioned,
add pivoting axle (weld bolt to chassis)
cut drill and mount lever,
add return spring,
make linkages to the pedal...
adjust linkages where necessary.
I think you get the idea ;) But I think KISS is in fact the opposite of fabbing a tensioner system.
Again, I'm not standing behind you and whacking you with a twobyfour if you go with a tensioner clutch;
So yeah be my guest;
but frankly I'd take a bet that within a few months maybe a year you'll find yourself ordering a TC online
and on that day... you'll hear a song in your head.. gentle at first...
until you hit the "confirm order" button.. and then with a crescendo you hear it.. the "I told you so" song..
https://www.youtube.com/watch?v=Uz1Jwyxd4tE
See that.. it's even by "The Hives" ..:lolgoku:
Which is why we've attempted to educate you on the subject, WE DO have the necessary experience & knowledge you require...
...WHY REINVENT THE WHEEL or "it's better to copy success than to invent mediocrity".
Now you're contradicting yourself, that's exactly what all of us have been trying to say from the beginning...
If you want to use a tensioner system, go right ahead, all we are saying is there's a simpler, reliable, workable alternative...
David Ham
Melbourne
I tried to make a tensioner setup like what your'e describing, chasgas, but it was a complete failure. It was very hard to drive, engaging quickly would stall the engine, I burned one belt up, and it only worked for about two hours of driving time. but, it costed zero dollars. I reckon you should get the rest of the torque converter and not waste your time with the homemade setup.
