Joel
What is the difference between a maxtorque clutch and a regular clutch??
you're likely running an extremely bad gear ratio and if you burn up clutches NOW
without adjusting the gear ratio properly
you'll burn up as many belts ($25 each) in about the same time.
PS BTW that is the least telling thread topic I've seen in a while...
congrats for that
and you had your bar set really low already with
threads like: "me again" or "Help!"
You can't change it because you're not a moderator....
Well Here is as good a place as any. 6:1 on 15x6x6 tires Stock predator, Cheap clutch:
Yeah SHE can drive!
https://www.youtube.com/watch?v=zFxPIefW4gE&feature=youtu.be
indeed.. 6:1 reads nice...
you should be good
So maybe it's another issue.. which is easiest to guess by looking at a pic (hint...)
So post some, clutch, engine sprockets.. kart... the more we see the sooner someone's able to spot something you might want to check.
(say a tight chain.. or a throttle stop or... IDK... your 14" to be 22" in fact)
But if your engine has 5 or more horses to ride on,
your wheels are indeed not bigger than 14" on the rear
and your gearing is indeed 6:1
and your kart with you in it weighs no more than 300lbs
you should be okay and it's not a setup error.
(although ideally that already calls for a 8:1 ratio so it's kindof stretching it)
but it shouldn't be an imminent problem and thus there is something else that's wrong with it if you burn clutches regularly.
http://www.diygokarts.com/vb/forumdisplay.php?f=6where do i start?
