Clutch question
Holybeen
Hattiesburg mississippi
Can anyone point me in the right direction as to how or what centrifugal clutch to use with this shaft. This was once a kart engine i just just didnt get to see the original setup. This is a friends engine they want to rebuild. I know its old and i think its a briggs.
Holybeen
No its not. Knew i shouldve said that. Doesnt have a snap ring groove on the end either. Not sure if snap ring is right but im talking about the little keeper thing like on an old tecumseh
Seriously? There's no keyway whatsoever? How was anything held stationary on the shaft?
I'm afraid, if there's no keyway, there's no way of locking a clutch in place, which is required to make it function; you either need to replace the crank of have a keyway machined in the existing crank...
firemanjim
Just kartin' around....
Houston Texas
That's a shaft that has been modified,ie, turned down to a smaller size. For what, I have no idea. As AFAIK, there is no industrial engine made with a output shaft like that.....
I have to disagree Jim..
there have always been such shafts and there still are such shafts availbale.. Honda calls them "T-Type"
Poboy kartman
Senior Moments Member
White Settlement Texas
I think Jim is the only one close here....Sid....are the odds really in favor of a metric shaft on an old Briggs in Mississippi????
And....you can secure a CC very easily....without a keyway....
First things first....lets see a pic of the whole engine....and you HAVE to measure that shaft.....my money is on 5/8"....
No the odds are not in favour of a metric shaft.. but I don't have to tell you,
that once Fortuna kicks your behind, she always kicks as hard as possible :D
So yeah, if bad comes to worse it's metric no matter if unlikely or not ;)
That blue ring looks like a friction helper, I'm pretty sure a nyloc nut should keep it on;
I'd be extremely carefull on gearing though ...
and to be honest, I wouldn't want that on a kart.. a mini bike perhaps.. a kart... nope!
Holybeen
Ill measure it and get some more pics this evening if i can. Its at a friends house so a little patience pls. After a little more research i believe this is a honda as sid said. This was on a small cart at one time. He just wanted to rebuild it more for the retro effect. I told him this may not be useable unless we cut a keyway. I personally believe its junk
Desertduler
Water pump, the impeller threads on the shaft.
I have many of them at my work.
The smallest one I have there is a Honda WH20X water pump.
Threaded shafts are common on water pumps.
