clutch question
trexep
texas
I am new to forum and trying to get an old dingo go kart working again, can i just replace the old comet clutch with Hilliard Extreme Duty 3/4" Pulley. Can i keep the old Torque Converter. are should i go a whole different way
It's all or nothing, I'm afraid. You have three choices.
1) Service your CVT and bring it back into working order (Best option by a long shot)
2) Purchase a new equivalent CVT
3) Purchase a centrifugal clutch and change your sprockets to bring the gearing to an acceptable ratio.
Your CVT is salvageable. I've seen a lot worse brought back to life. There's a stickied thread at the top of this section that gives you some great pointers on servicing your CVT. Throwing it out would be shameful. If all else fails, mail it to me. Welcome to the forum!
r_chez_08
Should be in the shop...
Cornwall, UK
Your torque converter doesn't look bad. With just a wire wheel, wire brush or even some sandpaper, some time and simple tools you can disassemble and repair your torque converter.
trexep
texas
thanks everybody please forgive me if i ask some really dumb questions. From what i remember the reason we parked it was the clutch was slipping and pulsing when starting...it been bout 12 years i was amazed the engine started on 2 pulls. Reason asking bout hilliard was i was told comet out of business. is it possable to take apart clutch and clean? after getting it going thinking about putting one of those harbor freight 212cc predators of it. I am trying to get it going for grandkids . Thanks again from an ol' karter
r_chez_08
Cornwall, UK
Yeah go ahead and clean it and dissasemble it. Do some searching on both here and youtube for good dissasembly info. A member called blazkoweiz (or something like that) has some real good info.
Check your belt and centre distance.
I don't understand why you want a chineese predator when you have a motor that started no problem after 10 years of no use!
trexep
texas
thanks i just watch the utube on cleaning i was just checking the video on that pretator motor ...hope all the young one take a heed to always put up ur motors right drain tank and put some kind of storage fluid and the engine will winter will. thanks to all from hotter than h**l texas (not sure bout language on forum) man karting has come a long way
trexep
texas
ok i warned u guy here come one of those really dumb question my poor brain is just blanking but...is the bolt that hold the clutch backwards or normal to undo...remember i warned ya bout my dumb questions
Bluethunder3320
take that CVT apart, clean it, and you can get any part for it at MFG supply. (great site, they have diagrams too)
or... you can take the easy way out and buy a new CVT for around $200
trexep
texas
goT clutch all cleaned up and fired it up ... run like it was almost new
THANKS EVERY BODY FOR YOUR HELP !!!!!!
