rgvkid
Charlie Don't Surf!
I think its a comet, there are no labels on it. It was on a used engine i bought and i used it on my HF2.5 build. It worked great for Hours and hours. I had to make a sleeve for it to fit the 5/8 shaft.
After days of riding i started it up and noticed a knock in the clutch area. When i pulled apart the chain guard a small spring fell out, seen in pic Clutch 6. Not sure what its from. Does it look familiar? Maybe from the engine, probably from a pen justed picked up from riding in the parking lot.
Anyways, I pulled out the clutch and took it apart to check. I noticed that because of the sleeve spacer it was only pushing against a small amount of the built in keyway so it was starting to bite off some of it causing the play and the knock sound. Can i replace this center part? or shave it down and have a machine shop cut a slot to add a key? Maybe not worth it.
How do the pads look? this is my first time taking apart a clutch and it seemed to work great when we road it.
Any advice would be greatly appreciated.
How would they cut a slot with in the cylinder, is that even possible?
