Bought the "Streaker" use with a new predator 212cc. Clutch and converter are WAY misaligned. Tried adjusting the converter plate, but still way off! I even shimmed the clutch to stick out farther away from engine. Only solution i can come up with is to modify converter platea as to be able to move it, an sprocket closer to engine. Any other suggestions? Thank you..
