Clutch issues ??
AkNoMad
learning fast
Alaska/Washington
So I built my first go kart.,put a 212cc on it.I start it up go 50 feet and hear a hissing sound and centrifugal cutch is smoking and red hot. Not sure what I did wrong. Tires are 22
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Count the teeth on your Axle and Clutch. Divide the axle gear by the clutch gear.
For example 72/12 6:1 gear ratio.
What do you have?
Well nevermind, with 22" tires you probably need a Torque converter rather than a clutch.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
On a 212 you should be fine with a 20 series. "AKA tav 2 kit". Unless you start going crazy with HP mods the $79 dollar Ebay Chinese model will do fine.
Still though you need to have a good Gear ratio even with the TC. and with 22s 6:1 should do it.
Poboy kartman
Senior Moments Member
White Settlement Texas
You think? I'm not sure, I don't know if those TAVs work too well sideways.
