God.. I swear, you fix one thing, and 2 other things break.
Okay- you opened the door to this...
A month ago, the plastic radiator tank on my '93 Subaru work beater split about 45 minutes away from home. I loaded up with water including a couple extra gallon jugs to get me home. I did a neat thing with vise-grips, and had to only pull over once to add water.
Once I got home, I made a patch for the tank with a strip of fibreglass, a bit of 16ga sheet, and a bunch of JB weld. It held for a month. Last Thursday, I was working 90 minutes from home and noticed my temp gauge climbing on lunch break. The patch was letting go. I did another neat thing with some vise grips and some paint stir sticks and drove back to the jobsite. At the end of the day, I refilled the rad and got a couple more gallon jugs for the long ride home. I ordered a new radiator and took my van to work on Friday.
Saturday night, I installed the new rad. I had monday off, so I took my wife for a drive up to Orillia, about an hour from home on the highway- figured it would be a good shakedown to test the cooling system, so off I went with my jugs of water in the trunk.
Just leaving Orillia, my tranny started feeling funny. Mis-shifting and slipping. I pulled over and sprung the hood- only to discover that I'd blown all my tranny fluid all over the road!
One of the rubber tranny fluid cooling lines going to the rad had split. Dang. I cut off the bad section, and clamped it back on. I walked a mile to a gas station and bought a couple quarts of ATF. Walked back, filled the tranny, and drove off...
10 miles up the road, my tranny felt funny. I looked up again, and literally saw a flood of bright new ATF climbing my hood toward the windshield!
Pulling over, I saw that the same line had split in the middle!
Now what? The dang hose was clearly shot. Taking it off the old rad and putting it on the new one was obviously more than it could take. So what do I do for some hose in the middle of nowhere???
The air conditioning system has been dead for the two years I've owned the car- got a wicked leak that I can't fix... So- out comes the knife- I slashed a section of hose out of the A/C's low side and spliced it into the tranny cooling sytem. I dumped in the remaining 3/4 of a quart of ATF and managed to find a gas station a few miles up the road, tranny slipping and all. I bought 2 more quarts of ATF, dumped it in, and drove home. I took the back roads, which was well over an hour of chewing my fingernails, as the A/C hose did NOT fit the fittings as snugly as it should (3/8" hose on 5/16" fittings- believe me, I
tightened those hose clamps!!!).
Got home okay- topped the tranny up full, and applied a second clamp to each end of the hose. The car was horrible the whole engine, driveline, and the left side of the body covered in pink he//. I went nuts with the degreaser! This morning, I drove to work very nervously (1 hour drive, stopping twice to open the hood). Seemed okay today, no apparent leaks, and shifting and locking like it should.
On the plus side, the cooling system (remember the radiator?) has been functioning flawlessly!
Sorry 'bout the novel, but I had to share that after your comment!
