Clutch ID
allanbranch
newbie gokart builder
Can you help me identify this clutch?
allanbranch
I need a #41 chain sprocket for the clutch, are clutch sprockets interchangeable?
Hillard clutches are a good brand, and will do fine on a gokart. That one there you can find different springs that will vary the rpm engagement speed of the clutch.
Sprockets are chain specific. As for 41 and 40 I think they are the same?
I believe that model has an interchangeable sprocket for different chains?
What is the vehicle and what is the motor?
Edit: as you can see, you can edit your posts, dont multiple post.
allanbranch
40 vs 41 is really just width of the chain, 40 is wider.
The gokart is a carter bros two seater, the engine is a 6.5hp honda.
I didnt know any of the 6.5hp honda's had any vertical cylinders, only the smaller displacements.
Edit: I see is a GC model.
allanbranch
Looks like I cannot get a Hilliard Fury clutch with a #41 sprocket. The drive sprocket is a #41 carter brothers (60 I think), so I don't want to go down the path or replacing it and the wheel hub and rim, also i have some #41 chain too.
I was going to buy this sprocket but I think I have a Hilliard fury racing clutch and that sprocket is one for a "Hilliard Extreme Clutch" sprocket.
I feel like I'm going nuts. How do I tell the difference between all these hilliard clutches?
allanbranch
It's a build, I really have three gokarts right now.
I bought this frame from a scrap yard for $30, just needed new tubes, a few new bearings, 1 tire and an engine. This was bought way before i knew anything about gokarts. Then I bought an engine from a friend, he had this clutch on it, he didn't know what sprocket I had, I bought the engine and clutch for $100 total.
So I have a carter brothers cart with 41 sprocket and carter brothers and an engine with a clutch I can't get a sprocket for a #41 chain on. Ugh. I'll just save the clutch for another build one day and buy a cheaper clutch with a #41 sprocket.
A month ago I didn't even know there were different gokart chains. This forum has been an amazing resource, thank you.
Yeah, you are going to have to match up your chains and sprockets. I would also keep that clutch for a later project. Hanging round here you are bound to start something else soon
qtband
St. Louis, MO
When using that engine on a kart, be careful with the direction of the exhaust. I most likely will be shooting right at the back of the seat. If so, post back here and we'll help you fix that.
allanbranch
Yeah, we're bending a pipe for the exhaust and covering it in heat tap. It's a pain but the engine cost me $100 to hopefully the exhaust won't be too big of a pain.
Thanks for the heads up though.
