I’m gonna nickname this kart Eleanor.
Please don't
As for fresh engine, and fresh oil... don't be surprised if it refuses to start up right away.
That's completely normal and after the first hour running it will start a lot easier. That is also when you want to make sure nothing has started to loosen.
The first 5 hours on a fresh engine meant to last are the most critical to check all torque values after it's gone cold because that when it's most probable to have something loosen up from thermal expansion. It is imperative if you want the engine to last that you don't flog the throttle and absolutely do not engine brake to slow down
If it doesn't have a magnetic drain plug, get one and change the oil after the first 5hrs... it will come out metallic charcoal in color, which is again normal for a fresh engine being ran in. After another 5hrs running change the oil again, it should be quite a bit more brown than black and will likely still have a lot of shimmer to it. After that second oil change things should be ran in enough to be a bit more aggressive but you should still avoid long hard runs against the governor assuming it's not bypassed or removed
