Clutch help - gearing/tire info
v8haha
Hi everyone, I'm new to the forum. I'm piecing together a go-kart for my daughter, and it's about time for it to run, and I'm having a problem which I believe points at a bad clutch, however, I don't want to throw parts at it not knowing for sure the setup is correct. Can someone help point me in a direction?
When my daughter is in the cart, it will barely move, and doesn't want to climb any hill, even a slight one. If I pick the cart up in the back, the engine revs completely and the rear axle drives like it's getting full speed. It's just when there is a load it won't go. That's what leads me to believe it's a bad clutch (it's old, rusty, and was with the engine that was in pieces when I got it). I cleaned up all the clutch packs as best as I could, but still hasn't made a difference.
I have a 5hp Briggs and Stratton engine
18" (18x9.50-8NHS) riding mower tractor tires in the rear
I am using a jackshaft that gives me some gear reduction
Clutch - 3/4", 10 tooth clutch
Jackshaft Input - 16 tooth
Jackshaft Output - 12 tooth
Axle Sprocket -52 tooth
I believe this works out to a 6.9:1 gear ratio.
The kart weighs roughly 150lbs. My Daughter is under 100lbs.
I am concerned with the rear tire size and gear ratio, that I might destroy a clutch quickly.
Any thoughts or input would be greatly appreciated!
You are correct, correct gear calculation & correct about the tyres being too big for the gearing; with 20" tyres, the gearing needs to be up around 8:1 or 9:1...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Here is a link to a handy gear ratio calculator. http://www.affordablegokarts.com/GearCalc.php
Will make it easy to find what gears to buy. I think in your case it would be easiest and most affordable to start by just changing the jackshaft sprockets.
You may find that clutch is still good, just needs the right gearing for those tires
v8haha
Thanks for the answers. I'll do more math on changing the jack shaft sprockets to increase my gear ratio.
v8haha
If I'm correct, if I change my jackshaft output to a 9 tooth, I'll but about 9.2:1, which should be a lot closer to where I need to be with my 18 tires, right?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
One thing to keep in mind. Using small tooth count sprockets (under 10 or 12) Is hard on the sprocket teeth and they do not last as long.
So jack shaft in at 20 may be better. 8.7:1 Close enough to Fabros suggested "8 or 9 for 20in tyres" and yours are 18" so..:thumbsup:
