Clutch gone on first outing didnt go well
gogogo
First timer
Nazeing Essex
My little boys first outing didnt go well. Having had the car checked over by the track mechanic i thought all would be ok.
I was a little dismayed when i collected it from him that he hadnt even started it up but just fixed the cosmetics on the kart.
So we went off with intrepidation only to start the car up and before we even pulled away the marshall in charge told me the clutch was going or had already gone or the engine was going to blow.
My boy managed a couple of laps but there was no pull on the kart and he just couldnt get any speed up meaning he was being buzzed by 5 cars at every corner and now has a slight fear of going back on the karts.
the mechanic has told me i am best getting a honda replacement however as my kart is a shark wtp b1 the enging is on the other side so in fact i will need a new kart.
Is it fairly easy / inexpensive to replace the clutch on one of these karts.
Any advice most gratefully and gracefully accepted.
thanks
James
r_chez_08
Should be in the shop...
Cornwall, UK
What motor is on the kart?
If the motor is a honda/briggs/techumseh between about 3 and 8hp it will probably have a 3/4" straight keyed shaft. You can pick up a clutch from £30 and up to £300+
If the motor is under 3hp it will probably have a 5/8" straight keyed shaft. You can get a clutch from £30
If the motor is above 8hp it may have a 3/4" or 1" shaft and the clutch would be £60+.
Pics would help.
Are you 100% sure the clutch has gone? Is the engine revving fully? How many teeth are on the clutch and rear sprocket, and how big are your tyres?
Edit: changed the prices for UK
Edit2: Searching on google for your kart came up with these clutch parts.
http://www.kartpartsuk.com/index.php?page=categories&catID=511&catname=wtp_clutch_parts
I am guessing you have a "proper" kart motor, not a "tiller" or industrial motor like a honda gx200
