I have an old Briggs 4hp layin around and im going to put it on my old vintage racer until I can build my mcculloch engine. I was wondering what clutch is decent but really cheap just to let my daughter to ride around on for a few months. I was looking on ebay and found a Max torque 5/8 clutch the motor is old and has no keyway just uses set screws.
Lots of us here have run across engines that had tapered output shafts without a keyway like yours. You'll need a keyway so the clutch can grip the shaft. No one makes a clutch to fit and work on tapered shaft engines like yours. If your able to machine a keyway into the crankshaft yourself that's great, go for it.
These 5/8" bore clutch models:-->
http://www.mfgsupply.com/GoMiniClutchCentMax.html/mv_session_id=gvgS456F claim to have a built in 3/16" key, so that means the cranks keyway would need to be just a little wider than 3/16" wide by approximately 3/32" deep.
The other alternatives are removing the crank and having a machine shop do this mod for you, (but It'll be pretty exspencive) or just buying another engine (or crankshaft) that's equipped with non-tapered output shaft and a keyway like the left end of this pic:
