clutch for old brigs
jbkurtzer
I have an old Briggs 4hp layin around and im going to put it on my old vintage racer until I can build my mcculloch engine. I was wondering what clutch is decent but really cheap just to let my daughter to ride around on for a few months. I was looking on ebay and found a Max torque 5/8 clutch the motor is old and has no keyway just uses set screws.
r_chez_08
Should be in the shop...
Cornwall, UK
I highly doubt that the clutch would hold on the shaft with no keyway.
You would want to cut a keyway with a dremel or take it to a machine shop.
Lots of us here have run across engines that had tapered output shafts without a keyway like yours. You'll need a keyway so the clutch can grip the shaft. No one makes a clutch to fit and work on tapered shaft engines like yours. If your able to machine a keyway into the crankshaft yourself that's great, go for it.
These 5/8" bore clutch models:-->http://www.mfgsupply.com/GoMiniClutchCentMax.html/mv_session_id=gvgS456F claim to have a built in 3/16" key, so that means the cranks keyway would need to be just a little wider than 3/16" wide by approximately 3/32" deep.
The other alternatives are removing the crank and having a machine shop do this mod for you, (but It'll be pretty exspencive) or just buying another engine (or crankshaft) that's equipped with non-tapered output shaft and a keyway like the left end of this pic:
jbkurtzer
Yes I looked again there is no keyway. Just a spot where there was a set screw. The end of the crankshaft is threded for a bolt. Those are the same clutches I was looking at on ebay.
Bluethunder3320
i would use a dremel to cut a keyway. as long as its relatively straight it would work.
if you screw it up no big deal since you can rotate it around and try again or bring it to a machine shop.
be sure to not do it all at once, make sure it doesnt get too hot.
Russ2251
AZUSA:Powered by LAWN-BOY
Patience is key...
Expect a few hours work. Payoff is big...especially when a machine shop can charge (potentially) as much as $250.
Do not expect it to be perfect...but keyway will be workable.
I've done it 3 times so far with a fourth on the way.
Each succeeding time has been better than the last. Practice makes perfect.
