Clutch doesnt have set screw????
jeckel7234
Ive got a centrifugal clutch im trying to put on my hf 212cc motor, the clutch doesnt have set screws or any other type of screw or hole that would look like it mounts to the shaft? So how do i mount it thanks
jeckel7234
By using a bolt in the end of your engine's PTO shaft (and a washer).
yea sorry i did put that in the original post i tried that, the part of the clutch with the teeth for the chain stays put for the most part but the part of the clutch that expands out slides all the way toward the engine leaving about 1/4" that would contact the walls of the other piece. Is a centrfiugal clutch supposed to be held together by something? or when i throttle up will it force the pieces closer?
jeckel7234
I dont see anywhere that looks like a snap ring would go heres some pictures front and back of both pies and down the shaft hole
jeckel7234
and in the second picture the crack, is that going to cause any big problem it doesnt seem to of made anything loose
That crack, and the others, indicate that the bushing is about to self-destruct.
If there's absolutely nothing there to hold the clutch together, install a locking collar on your PTO shaft right behind the clutch to hold it from sliding toward the engine.
r_chez_08
Should be in the shop...
Cornwall, UK
Nodroz, the PTO shaft stands for Power Take Off shaft. In other words, crank shaft!
I would replace that bushing, here is one that should fit.
Sorry, never owned one of these, so cannot help with the other issue.
r_chez_08
Cornwall, UK
May be the easy option since yours already requires over $10 in parts. You can get a new one for around $40 or a cheap maxtorque for $25
