Clutch does not engage
karospirit
This is the first go kart I have ever purchased. It is my son's birthday gift...which has now past for a week, and it still does not work.
It is a used go kart and apparently a homemade one. It has a Predator 312 engine, and that is all I know. The engine works. I did not ride it when I bought it (big mistake). When I got home, I tried it and the clutch does not engage. I opened it up and found the weight assembly to be banged up with one crooked garter spring. I replaced the assembly. I cleaned the grease off, the rust off. The belt seems new. When I push the kart, the right part of the converter and the belt move. When I turn on the engine and push gas, the left part of the torque converter engages, but the belt does not move at all.
I youtubed torque converters. My torque converter does not have a brass ring or a removable hub (the thing that goes on the crankshaft). I am wondering what to do. I tried contacting the seller but he does not respond anymore. He did say that all it needs is some lube on the spring.
I really need some help to a. figure out what torque converter this is and b. how to engage the belt.
https://www.youtube.com/watch?v=LVZ81fP1tmo
---------- Post added at 04:43 PM ---------- Previous post was at 04:42 PM ----------
Sorry couldn't help myself.
Predator 301cc.
---------- Post added at 04:46 PM ---------- Previous post was at 04:43 PM ----------
Can you show me a pic of this?
karospirit
301 cc :wai:
KartFab
Dallas, TX
It does have a hub. It needs to slide through. Can you separate them?
Wear buttons on driven unit? Are they catching on the cam?
Belt :203591 needs. 7 9/16- 7 5/8 distance between engine shaft and Jackshaft (assuming you have 6" driven unit).
Also, the flat side of the drive unit needs to be pretty close to lined up with flat side of driven unit. Check with straight edge.
Tire size?
Jackshaft teeth #
Axle teeth ?
seized hub...
As he said.. you have a hub and it's seized..
while having it off the engine
add penatrating oil and patience, remove the hub (mild force only), clean it with some scotch pad also the inside of the moveable sheave where it's been rusted on..
clean everything thoroughly with brake cleaner or rubbing alcohol (to get rid of any oil residue)
then spray some dry lubricant to the INSIDE (where the weights sit) and 'maybe' the hub itself..
the hub when done must drop through the sheave
but also sit as tight as possible (i.e. no wobble)
after that, I'm sure the TC driver itself is fixed.
(you might still have an issue with your gearing though... or belt alignment or....)
if you engine has a 1" shaft (which I think it has from the pics) you will not have a bronze bushing.
that's only installed on engines with a 3/4" shaft.
karospirit
I will get on this next weekend. Thank you all so far for the great help. The hub looks and feels like it is part of the unit. It does not move whatsoever.
To be continued....
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
While you have it sitting for a week get it soaking in Pb blaster or WD40 penatration oil.
I would trust advice of Sid and Kartfab. If they say it comes apart it comes apart.
karospirit
Wonderful news!
:wai::cheers2: I went and got PB blaster. That took care of a bit but the hub still did not move at all. I let it sit for 3 days. Still no movement but a lot of rust surfaced. Tapped it with a mallot. And then I got it out!!!!! How filthy....
Got more rust remover, a small wire brush, very fine sandpaper and went to work. Also cleaned the oily gunk off the rest of the torque converter. Put it back together, gave it some gas, and it worked!!!!!!!
My son's face was priceless. Two weeks after his birthday, his gift is finally working. Thanks to everyone here. Took it around the neighborhood. :)
Yay, oh yay.
Next question: Steering is super hard. I am not expecting servo. Also, the front wheels don't align when going around a corner. Is that normal?
Glad that TC is back in business :D
The front wheels should NOT align in corners
(the inner one should follow a smaller circle than the outer one)
To be sure yours is setup correctly (oh forgive me.. your son's)
please take three pictures:
straight down from above the front axle (all the way left, centered & all the way right)
karts with suspension are tougher to steer at times, but we can talk you through some mild modification to improve the Ackermann angles (if mot already perfect)
so that it'll steer as good as possible without powersteering or converting to rack and pinion.
karospirit
Here are the pictures
Itsid, what is your verdict?
The outer wheel turns in more than the inner wheel, as far as I remember
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
For his verdict... Please
uhmm.. yes, steering fully locked left and right... not left and right close ups (although they too might come in handy later ;))
What I can tell for now is that those linkages are likely not to close to proper Ackermann angles
(they look like they have been made without ANY Ackermann geometry in mind)
So I see room for improvement.
It's the inside wheel that should see a tighter turn than the outside wheel, not the other way around for sure.
