Clutch, chain and sprocket setup HELP!
JMack1995
Melbourne, Vic, Australia
hey guys,
i was wondering if it would matter if i had a 219 pitch 16 tooth centrifugal clutch onto a 219 pitch 66 tooth rear sprocket. this ratio is 4.125 does this ratio matter? will the chain fall off, will this work?
r_chez_08
Should be in the shop...
Cornwall, UK
Pics? What motor and wheel size? What clutch? At the moment that ratio sounds steep.
The chain should not fall off unless it is loose or out of allignment or excessively worn.
JMack1995
It Is a 16 tooth maxtorque clutch, 219 pitch. My wheels are 10 inch and m engine is 1.1hp, I know this won't be enough for good speed or might not be enough to move it at all but I I am trying to find a 6.5 or bigger engine.
jrmints1415
Naperville Illinois
