Clutch and sprockets questions
Marinetech
For those of you that read my intro, you know i have been around the block with Corvettes and Tunnell Hull Race boats. So this is my project: I have purchased a shifter style Kart with no engine. I am installing a twin cylinder 2 stroke 440 snowmobile engine on it. I am not mounting it beside me, I have extended the frame about 1 foot with proper size tubing and mig welded it together. This is a" how fast can I go" build, not racing anyone but the cops. I have also got a mounting plate ready to install as soon as I figure out exact engine mounting location. I have a 40 mm steel axle, but it is still hollow, just not aluminum. I am not using a CVT or a torque converter set up, or a jack shaft. If i have to push start this thing or use my starter to do a rolling start that is what I will do. So, this engine has a CVT clutch to operate the snowmobile, The clutch rides on a removable shaft that has a taper machine end that fits over the machine tapered end of the crank and uses a approximately 7-inch 1/2-inch bolt that ends up pulling the shaft and the crank together for a perfect no slip fit without any keyway. I bought the puller and was able to remove the clutch shaft from the crank. The shaft is over 1 inch in diameter from the crank end all the way down to about 1 1/2 inch from the end where it drops down to a one-inch splined area that the outer CVT hub would spline to. Now I have been looking for the centrifugal clutch that no one has or is willing to build for this engine because they all admit that they can't build a clutch to take the horsepower. What a bunch of pussies! They have quit before they even try. Well I know that it can be done because we have motorcycles with more than 40 hp. I have heard of people putting every kind of engine on a go kart except a B.B. chevy. My question is what are they using for a clutch? I need Ideas, from people who have done it themselves, not from people who have heard about it. One thing I do know that i am doing is putting twin rear dick and calipers on this death trap. I am looking forward to reading about what you guys have engineered that works. I also know that a size 50 chain at the least buy have not seen any 50 sprockets anywhere for Karts. Thanks for reading.
UP DATE: I have found a clutch company that makes a centrifugal clutch that is rated for 18- 40 HP. NORMAN CLUTCH, but it has a double groove pully for two V belts. That will not work so I have to contact them on Monday to see if they can put a chain sprocket on it. I am going with #50 chain. Any recommendations for #s of teeth on the drive sprocket and need to know where to find # 50 sprocket that will go on a 40 mm axle hub. anyone know where I can get the rear sprocket and what # of teeth I should get?
@marine tech, most of us do 6 to 1 (normally 60T sprocket, 10T driver) but with your powei it could be different. One thinge is wheel size. Check out the speed calculator on DIY’s ‘all the way home’ page, it may help. It’s nice to talk to someone who really knows what they want.
Ok but where to get #50 chain sprockets for the axle?
Check out motorcycle websites, a quick Google search got me some results.
Edit: usarollerchaigns.com seems to have a large selection. FYI I've never ordered from them, check out their reputation first.
