Rear tire size is 145/70/6
. Ok so If I go with 72 then should I go with 10 or 12T clutch and what chain?Sorry, I'd missed that. Another reason to avoid multi-posting.
Anyways- You are best off getting a rear sprocket of 60-72 teeth as suggested above. If you're aimed more towards long, interrupted high-speed runs, then nearer to 60T. If there's any hills or you think you'll be doing stops and starts and generally goofing off and having a good time, then a higher tooth count (towards 72) is for you.
No I actually have to buy a sprocket and clutch, the sprocket that was on the axle was only 30T, so that's why I needed to know what size sprocket and clutch, does it matter if I get a 3/8 or 1/2" pitch sprocket?10T. Now- you said half-inch pitch, so, #40 chain.
Your choice> all things considered, I still suggest #40.
