Clutch and/or Jackshaft help!
hirum24
Here is what I have first off. Friend had an old go kart buried in a barn and gave to me for my kids to play with. Said it might need some work. Engine works fine but I believe clutch is burnt out and might need to be geared differently.
Engine = Briggs.....intek 206, 5.5hp. 3600rpm
Clutch has a 10 tooth sprocket
Rear axle has a 60 tooth sprocket
Rear tires are size 18
Kart weight is 160
Rider weight could be between 100 to 260 lbs as it is a 2 person seater.
Clutch is burnt out cause it won't move unless it's down hill. Ha.
Main use will be flat land and some small little hills but nothing huge. I'm not looking for top speed or trying to race just kids playing in the field, driveway and backyard.
So what I'm needing to know is what sprocket sizes to use? Should I install a Jackshaft and if so which size should all 4 sprockets be? Kind of clutch to be used and chain?
I hate math and really have no clue here cause this is a first for me.
Please help?
Maybe something like 10 on the clutch going to a 14 on the Jackshaft, then a 10 on the other side of the JS going to the 60 on the rear.
8.4 : 1 should be good with 18" tires. You might only do 23mph at 3600 RPM, but it will be easier on the clutch.
