clutch always spins
bott12
Hi,
I am new here. I love small engine sports, but am new to go karting. To try it, we bought a cheap hardware store type go-kart. A problem I see is that the clutch always spins. So if one of my kids holds down the brake, the clutch chews up the belt. The unit is used, and the clutch may be aftermarket. What is going on?
hello and welcome.
Going to need some more discription of what the vehicle is and other spec of motor ect.
pics are going to help alot aswell.
bott12
bott12
I just posted pictures and am waiting for moderator to approve. I am open to using a different drive system if this is not adequate.
Welcome to the forum. If I am seeing things correctly, it comes down to training. The clutch is centrifugally actuates- throttle up, and it engages. Pressing the brake at the same time will create a great load on things. The weak link goes- burning belts. Much like doing it with your car, it's not good.
Now- You could switch to a chain-type clutch, but then you are removing the weak link. Now, instead of burning belts, you'll be burning up clutches.
Once you have replaced the belt, be sure to tension it correctly. Now- If the kart is trying to drive away with no driver throttle input (hence burning belts when your kid is trying to stop) this indicates that the engine or throttle linkage need some attention.
bott12
I think the clutch is always engaged. It never stops spinning. Could the idle speed be too high? The clutch gets really really hot.
idle should be set to about to the point where it doesnt die. If the clutch is still engaged by that point, then is a new one.
Let's clarify things a bit- if the wheels are off the ground, or there is no belt installed, the clutch WILL tend to spin. Judge the clutch when it has a load on.
