clone main jet
Bluethunder3320
im thinking of putting on my K&N style filter. so about what jet size do i need? i have 2 spare stock jets to mess with.... what size drill bit should i get? i have tried boring them with a torch tip cleaner but it does nothing really...
EDIT: id rather not have to order a jet online because i have been getting a lot of crap off the net lately... and i dont really want to pay shipping for a little jet.....
Put the filter on, put a fresh plug in, and do a few test pulls. Odds are you won't need to re-jet just for a filter (if everything's all right to begin with).
Bluethunder3320
and an exhaust.
i rode it for a while like that and if i gunned it too hard it stalled. sounded a little like it wa struggling. i got more power out of it with the stock airbox.
slideways
.036 on main. The pilot jet should be opened up just a hair too. That will improve off idle pickup.
Bluethunder3320
where is the pilot jet? the thing thats adjustable on the side?
and .036 that would be after drilled not stock right? just making sure haha.
slideways
If you're lucky you have the old adjustable style. You shouldn't have to drill it if you can adjust it. The jet itself is a black plastic "plug" with a delicate o-ring holding it into the carb body. You have to remove the idle adjuster screw and gently pry it out with a screwdriver. The tiny hole in the bottom is the jet orifice which is what you would drill. To tune the carb like this i like to jack up the rear tires with it idling and stab the throttle. Keep turning it in to improve the response until it bogs which is when you know its too lean. If you have it out too far it will chug chug a couple times because its too rich.
.036 is the size you are drilling it to..not what you are adding to it. I'm not sure if this is the #90 that they talk about. Drill bits that small are numbered not physically sized which is why this is the case. There are conversion charts online which make it easy to see.
