Clone engine Problem
irelandbiker
I did a stupid thing when i removed the govenor i didnt screw back on all the bolts holding on the side casing just 1 without thinking i went for dinner
I started the engine everything was fine till i noticed oil leaking then the side casing popped off and the engine hasnt started since even do i cleaned it all up
When i pull the pull start the shaft spins very freely and it sounds like theres no spark but the spark plug is fine
Any suggestions?
oscaryu1
VERY freely? You gotta problem there. I'd say blown connecting rod or such... you should feel SOME resistance from the compression.
tenlizard
go inside engine and see if rod is broken. if you dont kno wat im talkin bout thentake pictures and we can see wat the problem is. see if there is any metal parts on the bottom. if there is describe it. there was oil starvation and before you could stop the engine, a rod was thrown or maybe the cylinder was scortched or maybe the rings wore all the way down or something.
oscaryu1
A thick rod that comes from the crankshaft into a hole to the engine, if that's broken, time to buy another one.
