I have a clone engine with a mikuni carb (non slide carb) probably around a 5-6hp engine. I need an idle mixture screw. Does anyone know where I can get one. Is there a possible replacement carb? What size and where to get?
Clone engines do not come standard with Mikuni carburetors. You most likely have a aftermarket racing Clone motor. Commonly used carburetors on these are the 22mm's.
Where could I get an idle mixture screw? This carb has mikuni engraved in it. It does not have a slide like a motorcycle would, aren't all of the 22mm mikuni's slide carbs?
