Clone engine mated to motorcycle gear box
highsierra1983
Had an idea, thinking of attaching a clone 15 hp engine to a 200 atc engine.
Thinking of taking out the head piston and just have an input to the clutch
Any input would be appreciated. It would be nice to have a gear box and auto clutch on the cheap and I have a few old
Motorcycle engine without carbs wiring and other stuff.
highsierra1983
Just reading, I work alot I guess
My kids are getting older now and i have 300 acres and a barn full of engines atv frames and want to start putting them to use.
smgs92
LOL 2700 of it is farm land so not too much too room to play with ;)
If you go through with it make sure to take pics because hopefully you're successful and I love this concept but it's more than I can imagine.
smgs92
hahahah well I don't live on that farm but I own it and can go on it whenever. It's a 40mile drive though.
For the world-class pain in the bass it WILL be, you're much better off to simply fix one of the ATV engines, and install the whole thing. There are a lot of hurdles you will have to overcome to use just the tranny.
fowler
Bullsbrook West Aus
Ha 24'000 acres here
But yes it would be easiest to fix an atv
Otherwise u could make an adapter to bolt a sprocket to the old flywheel mount in the atv engine
But u may find the atv crank won't take the torque twist
highsierra1983
Oh it better take the torque twist.
I have 3 atv frames but none with engines
It was just a thought as long I can get the power to the clutch it should work.
I'm cutting the crank flush at the rod bearing. Half-a$$ balance it then figure out how to mate my 15 hp clone.
