mark123
I just bought a new clone and removed gov, filed key for 8 degree advance, put in 18 lb springs. It is hard to start and when I choke it it backfires bit will eventually start. I had to raise the idle to approx 1900, anything less and it stalls. The carb has an idle mixtures screw and was close to 4 turns out from the factory and the stock jet is #70, I didn't check the stock idle jet size. What should I do so I can lower the idle speed without it stalling, I read on another forum to drill main to #90, would this help idle or should I drill the pilot jet larger, if so what size? Should mixture screw be in more?
