chopper project revised
907debow1234
907 racer
Soldotna, Alaska
So got a mini project from a friends house where it was a project of many. Basically who ever was over an with a few beers in hand would all tinker an build. Finally got him to cut the project loose and I dragged it to my yard where I'm the sole person working on it.
Once I took a closer look. I'm afraid much will have to be redesigned... seat I made and sissy bar from rod iron. Extra rear fender from an old honda. Hooked up the disc brake on the front. The springer front end is aluminum, which may hold up as long an no fat people or rough riding effect it. Extra engine is a teschemu, have no idea what it came off of, but i have to mix the fuel first, so that will help with id. But after some love she fired over, I'm not sure what wires on the engine are just yet. I also wish to put a head light on it when time comes.
If you look close sprocket has been welded an screwed to the shaft because they couldn't remove old part stuck on the key.. so I need a new shaft I assume... I plan on centrifuge clutch. I also am working with the tire. Has sprocket welded on... so need to cut an buy right axle. Not sure which one yet.. an rear brakes of course. So sorry for long read so here is pics. More to come
