Choices in predator engines?
Thekoontz
Pasadena, Maryland
This may be a dumb question but I've all but decided to take out me 6hp Tecumseh in my sons grave digger kart and replace it with a predator 6.5hp. I see a part number 69730, 69727 and a 60363. What are the differences?
Second. what are thoughts on replacing my oem engine with this? I have an electric start, if I want to keep it should I go with a bigger engine that has it. From previous post, I understand I have to stay within a 3/4 shaft. Or should I go with a 6.5 and mod it?
Any thoughts and suggestions would be very much appreciated.
Thank you!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
3 model numbers. Probably 1 vertical shaft 6.5, 1 Hemi horiz. 6.5 (EPA) and I non hemi for stupid California Smog emissions (CARB). But just guessing.
Yep the 69727 is "special" for California. Other 2 look the same maybe hemi and non hemi
Thekoontz
Pasadena, Maryland
Looks like the 69727 says epa & carb, shaft 2-7/16 max rpm 3800.
The 363 and 730 both have 2.43" shaft and everything else is the same exept the 730 has max rpm of 3800 to where the 363 has a max of 3600.
What a hemi? Is that the 730, give you higher max rpm?
Thekoontz
Pasadena, Maryland
Just found a coupon that says 69727 is California only...so that narrows it down to 2. One has 200 more max rpm, so that I assume would be a hemi?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
ok 2 7/16 is 2.43. and Yes you do not want the Cali special.
between 363 or 730. One is a hemi one is not. the OHV valve covers are different, I do not remember which is which.
Hemi is short for hemispherical. Referring to the shape of the combustion chamber . I understand it is a better motor. But technically speaking I don't know why.
btw. I just bought the 79cc. Said not for sale in Ca. So I bought it on H.F. .com and they shipped it to Ca. I win. LOL
Kansas City, Kansas
Hemi is better because it gives more compression in a smaller serface area while also giving more volume for BOOM. On smaller engines the effect is not as drastic but ever bit counts.
Great vid on this, he also does great suspension
vids.https://youtu.be/qLns7ibeUps
firemanjim
Just kartin' around....
Houston Texas
It's the same basic platform. Should have no problem fitting.....
EDIT
You will need to make a new header so the exhaust exits outside the body..... NO biggie....
Thekoontz
Pasadena, Maryland
Okay, got the predator 60363. Now to get the mods done and install it on the kart. I'm thinking...removing the governor, billet flywheel, oil sensor removal and stage 4 from omb warehouse. I think that should make it move, I hope! I'll have to check it out and see what'll it do to make sure it won't be too much for my son, if so I may have to put a stop on the throttle until he grows into it.
Any other mods then what I'm doing should be or recommend doing while building it?
Thanks!
Kansas City, Kansas
Thanks!
why remove the oil sensor? It's there for a reason. unless you keep having shut off problems and know you have proper oil levels you should keep it.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Don't remove wiring for the oil sensor. reroute them to a button on the dash. (momentary/horn/start button) that gives the operator an instant kill switch.
Hippie: Yes these oil switches always give you shut off problems on a kart.
Also why spend the money on the engine mods now if you have to restrict it down for your son. When he grows into it then spend the money on the mods.
Thekoontz
Pasadena, Maryland
Thank you, I will not remove the wiring but use it as you say on a kill switch.
Engine mods are for me :lolgoku: and for my son I can tone it down a bit for him. :thumbsup:
firemanjim
Houston Texas
If you don't disconnect the low oil sensor, your engine will shut off on every hard right turn.... (its gonna shut down when you turn hard either way.... ) The reason is because the oil gets slung to one side in a turn. The sensor thinks "oh no! No oil!" then shuts you down.... A half second later, the sensor is back in the oil, but it's too late. Gotta climb back out and start it again...... After doing this a few times, you'll disconnect the sensor like the rest of us..... Just make sure you do regular maintenance and keep an eye on the oil level..... :thumbsup:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
not to mention the predator low oil switch is such a nice shut off. Most gokart wiring you have to "hold" down a button to ground the ignition and wait while holding for the engine to die completely. The low oil shut of routed to a button kills the engine dead instantly with one push. Great for kids and rookie drivers. cause its like a panic button.
