Check my parts list?
ZeroRomeoBravo
Minnesota, USA
I want to build a go kart, and have built a basic parts list. What am I missing or don't need?
Item
Engine
Tubing
Clutch
Rear Axle
Sprocket
Chain
Rear Wheel L
Rear Wheel R
Rear Tube L
Rear Tube R
Rear Tire L
Rear Tire R
Rear Brake
Seat
Engine Mount
Front Wheel L
Front Wheel R
Front Tire L
Front Tire R
Front Tube L
Front Tube R
Front Shock L
Front Shock R
Wheel Mount L
Wheel Mount R
Tie rod L
Tie rod R
Pitman Rod
Steering Wheel
Gas Pedal
Brake Pedal
L refers to left, R is right.
Depending on the brake caliper it also may need a bracket for mounting. (I'm assuming a disc)
KartFab
Dallas, TX
brake bands would need:
A rod welded to the frame that one side of the brake band slips on, which will have a pin that holds it in place.
The other side of the brake band will have the brake rod attached to it, with a pin that holds it in place.
Then some type of return spring/mechanism that forces the brake band outward when you are not stepping on the brakes
