Cheap tach on Predator, settings?
Noseoil
Terrible Tim
Tucson
Have a Baja MB165 with the Predator motor & TAV30 in place. Here's my question. I bought one of the cheap Chinese tachs (one button adjust, tach, hour meter, etc.) & put it on the hemi predator today. I set it up with the "correct" code for a 4 stroke motor (1P2r, one spark per 2 revolutions) & got about a 4000 rpm idle reading like that. Hmmm?
Screwed around with it at different settings & finally settled on the code for a 2 stroke motor (iP1r, 1 spark per one revolution) which gives me about 1900 rpm at idle, which actually seems close to right, as it's a factory motor with no mods done. Still need to ride it some to see full rpm's, but has anyone else run into this problem with this POS tach?
Second question, I haven't messed with the governor at all but I did unscrew the stop/adjustment screw holding the butterfly at about 1/2 open from the factory. Pulls a lot better now & winds up tighter, or so it seems. Are there any issues with doing this if the governor hasn't been touched & all springs, linkage & stuff is still intact? Runs a lot stronger & I have yet to feel the governor work at all on this motor, but I don't have a really long straight to let it wind fully.
I need to get clocked to see what type of top end I have now with the TAV & factory rear sprocket. Should be about 40, I guess, but it's a lot different with the new motor & TAV. Thanks, tim
Bbqjoe
Banned
Location, Location
Your idle sound a bit high. The book says something like 1200. I have mine idling nice at about 800.
I don't think you'll have any problems with the screw all the way out, or removed even.
Noseoil
Terrible Tim
Tucson
OK, thanks Joe.
Did some thinking & figured out the problem with settings & the tach. I'm old now & have always worked on stuff with points, coils & wires. I forgot that the Predator just uses a flywheel magneto setup with no real ignition system, so it is actually making a spark each time the motor turns. It fires once on the compression stroke & the once on the exhaust stroke. It actually runs like a 2 stroke motor on the ignition system, so problem solved.
Also, I looked up the factory settings & idle is usually set at "about" 1800 when the motor is built, so I can slow it down a bit now that it's getting broken in a bit more.
Bubba_Z
Bubba_Z
Western NC
Broke, yea FHB can break it.....in, out,over and under.
He has never meet a engine that didn't shiver when he picks it up.
Noseoil
Terrible Tim
Tucson
Thanks for the suggestion. If I had deeper pockets, I'd use the FHB type of "break-in" system (ball$ to the wall until something breaks) to see how it goes, but I'm trying not to spend too much on this thing (yea, right).
I'm using a 10w-30 synthetic (the high zinc stuff) to run it in with & will change it out & look at what's in the oil at about 10 hours. I know people will cringe at using synthetic for break-in oil, but from reading, a lot of new motors are run with it so the worst I'll get is maybe reduced compression, more blow-by at the rings & more oil consumption. It's running much better now & has more compression than it did out of the box, judging from the pull on the rope to start it. I guess we'll just have to wait & see how it goes.
Still thinking about a "few" more parts to let it breath better but $ is maxed out for the month now....
