Cheap live axle
Kbaker
Oklahoma
Hey I'm wanting to put a live axle on my cart and was looking for the cheapest way. I'm not scared to build something, but need a little direction. Thanks
Jr. Mechanic
Waldo, Wisconsin
When I made a drift trike with my dad, I found a piece of pipe that was straight and had fairly thick walls. I threaded the ends and welded up some hubs made from pipe fittings and a steel plate.
As long as the go kart isnt too heavy, A pipe should do the trick:thumbsup:
You should be able to find bearings that will fit the pipe; measure thoroughly
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Yeah that video they were so dumb they did not use keyed shafting. Check out the DIY hubs at 6 minutes in. Sketchy
