michaelr123
- Messages
- 13
- Reaction score
- 0
hey everybody, i know i sorta double posted here, but the other topic isn't to do with my go kart build, any way, now that we have that out of the way, on to another issue i have.
me and my friends are getting together to build go karts that we can race together and just have fun with for under $300. i've pretty much got it figured out, but i do need a little help on the clutch and engine.
i want to use the predator 212cc which is on sale right now for $120! its 7hp and a great engine as i've heard on many reviews and youtube videos. one of my friends says we can get away with the 99cc and save some money.
my thinking is that the 212cc will be much quicker and easier to get running fast enough while making it a single gear system. where as the 99cc could work, if we get the gear ratio just right and split it into a high and low gear, which i think is way harder and more expensive than just buying a more powerful engine and setting the gear ratio more towards top speed and just using the straight horse power to give it the acceleration we want.
as for the clutch, i literally want the cheapest clutch i can find that will still work, i know the shaft is 3/4 and i want to use number 40 chain because that's what i have left over from my last build. can i find centrifugal clutches at say, the junk yard?
as for gear ratio with a predator 212cc, i was planning like a 2:1 or 3:1, meaning for every spin on the engine shaft, the back wheels would turn a 1/2 or a 1/3 of a rotation. i used a calculator for speed and got 45 and 38mph with 10" wheels like i want to use. so a 10t on the clutch and a 20-30t on the rear shaft? will this result in pretty good acceleration? me and my friends are all around 160lbs and we are keeping the go kart super small and light, i'm guessing under 300lbs total for sure.
any help is greatly appreciated from the one on this build that is figuring everything out!
