Cheap comet 30 clone parts on BMI
r_chez_08
Should be in the shop...
Cornwall, UK
Thought this may help someone-
For people looking for replacement tav2, tav30 or 30 series parts then BMI. they sell both the driver and driven for around $85 together. That is just $110 for a kit with belt!
See here.
Sure you still need a jackshaft, which is $4, a jackshaft sprocket which is $10, two bearing hangers for $6 and some bearings, or you can buy BMI's $30 jackshaft kit with everything you need including a spare sprocket.
Total is around $140+ P+P which is $30 cheaper than the cheapest kit.
Just an idea for those who want a CTV and do not mind doing a little DIY, or own a CTV that needs fixing.
r_chez_08
Cornwall, UK
Yep. I just recieved a sprocket from willards in the USA. sprocket was $21, shipping was $16. Worth it for me, I have had enough of faffing with sprockets!
Nodroz
Belgium (Europe)
Exactly, r_chez. The shipping costs are enourmous if you compare it with what you bought.
My friend bought a Go Pro in the states some time ago. The shipping costs were $100. When he goes to the delivery station, here in Belgium to get his package - he got a fine of 120 euro. This includes taxes on the GoPro Price AND the shippinh costs. Sometimes you have back luck and the duane opens your package to see what's in. If they do so, you pay a lot! At the end he paid more for the shipping costs than the GoPro itself.
Sometimes you also have the problem that shops in the USA simply don't want to send your package to Europe, or they don't accept european credit cards. I've googled a bit for that, and it appears that some people from the Netherlands (from other countries aswell) live in the USA and are doing bussiness with buying stuff there, and sending to Europe. Anyway, the high shipping costs won't go away...
mfgsupply has a fairly shipping price. I think I'll order my #35 sprockets there, because they're unfindable in Belgium and surrounding countries.
r_chez_08
Cornwall, UK
Wow, that sucks! You could use #219 sprockets from the UK, shipping may be cheaper. Are there not Belgium standard chains, as there are British and American standards?
Nodroz
Belgium (Europe)
Yes there are standard chains which I think are family of the British ones.
I was able to order a centrifugal clutch with either chain size #35 or #41, yet I cannot get a sprocket for on my axle. I really don't understand how this is possible. Maybe I'm not searching good enough, although I have contacted several shops about it. They've never ever heard about those chain sizes.
r_chez_08
Cornwall, UK
Make sure you do get the correct size. A piece of farm machinery we have uses british standard 1/2" chain, 08B size. It does not fit on my #40 sprocket, it appears too short between links! Almost like the British standard is 12.5mm and American is 12.7mm! It is fine on the smaller sprockets though.
I have a #219 clutch drum and parts that fit maxtorque. I think I also have a chain. If your clutch is a maxtorque you could get a #219 sprocket and use these parts. If this would work out cheaper it may be an option for you. Shipping from UK to Europe is not bad.
Edit: you can get #35 chain from eBay UK or bearingboys.co.uk.
No sprockets though. Hence why mine came from America.
I just got my sprockets from an engineering company and had the boss machined off to give me a plate sprocket. It was for my minibike, but I needed a plate sprocket, and not one with a boss.
You can see what the sprocket used to look like, and then after it was machined. You have kinda got to get creative with what you do if there is no appropriate shops near by
Nodroz
Belgium (Europe)
Yes! That's exactly my problem. Don't ask my how, but a local shop had a #35 chain laying in his shed. He said it was off a American Lawnmower. Anyhow, I got that chain and bought a sprocket with the same dimensions (I didn't know much about this stuff yet).
The chain didn't fit, but I pitch was the same. I machined the sprocket to make it a little bit smaller. The teeth of the sprocket now came through the chain, however it is not possible to completely turn the chain around the sprocket, because as you say, its 0.1 mm smaller or wider.
Thanks for the tip btw!
Back on-topic: For those who life in the USA or for those who're willing to pay a large amount for shipping costs, then go for that set! It looks very nice!
