Chainsaw warm starting problems.
Jake.B
California-USA
I have a 40cc chainsaw that starts OK and it runs like a champ but the problem is after it has been running at full throtle for a while and you shut it off its a pain to start. Is this pressure build up in the gas tank or what do you guys think?
Jake.B
California-USA
Ok it used to not do it. Untill i hadent ran it for around a month give or take a week. Does this narrow it down a bit?
klicky96
Sandusky, Ohio
Drain the gas/oil mixture completely out. Get some regular 2 stroke oil and fresh gas and mix some up. The problem with hi performance racing 2 stroke oil is that some, not all, can be thicker and/or richer. When it is thicker, the gas/oil mix doesn't get through the carb as easy.
Jake.B
California-USA
Ok thanks, so basicly when its running it is fine because their is suction through the carb, but when you go to start it it is to thick. Should i remix and add more gas to the mixture or just use regular 2 stroke oil like you mentioned?
sexyvicta
could be a crankcase leak...they tend to get worse when hot. However 9 times out of ten the spark plug is the culprit on small twostrokes. try a new one
klicky96
Sandusky, Ohio
Yeah, I have a 1985 Stihl 028 Wood Boss. Runs like a champ, but I had to replace the carb gasket last summer. Thats honestly the only problems thats ever been wrong with it and my dad bought it brand new.
sexyvicta
Yeah the engines about 20-30 years old and idk if the plugs ever been replaced so thats probably the problem.
i've had this same problem with my weedeaters, hedge trimmers and chainsaw a few times and has been the plug everytime except for one weedeater which seems to get vapour lock in summer when its siting in my van. You can check to see if its the tank vent by trying to start it with the gas cap removed(when its hot and wont start otherwise).
has always been ngk resistor plugs which have given me the hot starting issues
DustinWolfe
Meridian, Idaho
i thought i would mention this i have a chiansaw that does this and it is indeed vapor lock. if you run it for more than about 20 mins no matter what your mix you end up with boiling gas. may or may not be relevant here just thought i would mention
South Kart3377
Kart designer
Va
My dad has one of those fast cutting machine, Nearly cut his leg off at least 10 times. Those things can do some cutting quick. :wai:
klicky96
Sandusky, Ohio
I got 2 nice cut marks on my leg haha almost the same spots too. Its got a lot of power and I pinched it, and when I yanked, well, slid right across my knee at near full throttle.
I would NOT take chainsaws lightly. I have seen enough horrifying injuries from these things to last me a lifetime. I work for a large forestry company, so I have seen what can happed.
Never us a chainsaw without the correct safety gear. You might get away with it for a couple of years, but one day you will do something stupid, and that can be the end of your life, or the loss of a foot.
Safety gear includes chainsaw pants to protect your legs, visor, earplugs and steel capped safety boots.
You can laugh at me now, but believe me, something can and will happen in the future. Accidents happen so fast you can't stop them.
Enough of the Public Service Anouncement. :D I would also change the plug first and see what happens
klicky96
Sandusky, Ohio
Landuse, I know what your talking about. There is always the risk factor even with the safety gear, but you are always more safe with the stuff on.
