Chain tension varies
Poboy kartman
Senior Moments Member
White Settlement Texas
Like Fab said- (sorta)- posts like yours do more good than harm. You can never look at any problem from too many different directions, especially when dealing with problems online-where, in the best of circumstances, information relevant to the problem at hand is going to be limited.
We're just here to give a hand to those that need it and a (good natured) hard time to those that don't.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Ok, thanks.
In my goofy experience, and racing experience, when putting an axle on:
1. Bearings & hangers in place, not tight.
2. Slide axle in, or hang it that way, loose.
3. Spin axle, make sure it's straight, should slide freely side to side.
4. Leave sprocket carrier & brake disc loose, do them later.
5. Slowly tighten bearing hangers making sure axle still spins freely... if not, tap axle back & forth as you tighten, keeps the bearings aligned. If they're off, or you set the set screws first, the axle will bind and not spin well at all. The axle can go a bit off because of the tight pinch caused by the set screws. Think about it, tighten the set screws before the axle bearings are in place... and something will give. It could be the frame, it could be the axle. but it could be enough to cause an issue.
6. Once spinning freely in the tightened bearings, Lightly tighten set screws on bearings to axle, or do what I do... put collars on it & leave the bearing set screws out of the picture... it lets the axle "float" a slight bit and retains free movement.
7. Once tight and spinning freely, Floor it!
Kelly
I wish I had this list in the first place. But we eventually got to #7.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Also finally heard from BMI they gave me all my money back on the bad clutch and paid the shipping for the replacement. Not too bad considering it took 7 days 4 of which were a long holiday weekend. and 2 days were their email would not open my videos. Besides I bought the cheapest clutch they had in the first place. live and learn
Oxymoron
Newbesque builder.
Maryland
Good to hear it worked out for you, now you and the kids can have some fun :)
Sent from my XT1060 using Tapatalk
