Chain pitch and many questions regarding.
carter
So I've gotten my sprockets off and am planning on replacing them, my first question is, Do they make split sprockets for #40 chain with a 3 1/4" hole and an 8 bolt pattern? If not, do they make ANY sprockets like that. If not, what would be a pitch I could change to that would be able to handle around 15 horse through a torque converter that can be found like that? Also regarding that, at what point would a comet 40 begin to prematurely age and eat belts in terms of ratio figuring about 300-400 pounds with rider? I think that's all I've got for now, thanks in advance.
The question about the Comet 40 series all depends on gearing as well as where you are going to ride. Tyre size is also important. Give us some of that info and we can help you out
carter
Mostly grass, tires are 18x9.50x8. I'm asking what gearing assuming 3-400lbs and the things mentioned before, might cause that.
Given what you've given us, I wouldn't gear any higher than 5.5:1 or 6:1 depending on terrain and driving style. If you're doing a lot of stops and start or hilly areas, gear deeper- 6:1+ up to 7:1 or so.
The Comet 40 is VERY tolerant of abuse- I beat the spit out of mine for years with nary a hiccup, but in addition to potential wear/damage, there's a performance consideration.
I ran a GX340 (11hp) @4200RPM through a Comet 40 at 4.8:1 on the same sized tires with a similar total weight. While the 40 put up with it, acceleration was lacking, and I could tell I was pushing my luck with it.
carter
zwell I"m at 5.4:1 now, I might try 5.2:1 and see how that is, I wanted to try splits so I could fool around with my ratio a bit, but so far I'm having a helluva time finding a sprocket with a 3 1/4" hole and an 8 bolt (evenly spaced) pattern at all, let alone a split for #40 chain.
KartFab
Dallas, TX
you dont necesarily have to buy splits, 'they' (you can find) make solid steel's that you can bolt on. The best way to fool with gear ratio is to change out the jackshaft sprocket, they are cheaper anyway, and you probably won't need to shorten your chain, just move the motor mount a little with the sprocket change.
I would go with a #41 sprocket with 420p chain if i were you, buy the most expensive 420p chain you can.
carter
The problem with that would be that I would go from a 5.4 to a 4.9 just by adding one tooth on the jackshaft, however subtracting two teeth from the axle takes it to a 5.2 which is far more gentle on the CVT and will bring better acceleration
Any particular reason why the chain and sprocket mismatch and the #41 chain?
Maybe its just me, but I would be more comfortable with 6:1
any particular reason why?
The reason why I would gear to 6:1 is that you will have more torque while not sacrificing too much speed. Any higher than that could potentially put strain on the TC
A #40 sprocket is wider than a #41 sprocket
carter
It came stock at 5.4 to one and I can get it to full speed in about 100 feet, and mind you it has a pretty high top speed.
I know this, what I'm asking is why he told me to get a #41 sprocket and a 420p chain.
Probably because 420 chain is dead strong (motorcycle use). You can safely use wider chain on a narrower sprocket, but not the other way 'round.
