Chain lube...
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
After riding my kart all night :yawn: chains wore right out "garbage"... About 30 miles
I lubed it about every 3-5 miles with motor oil but it seems to fly off really quick.
I ride on gravel so there's lots of dust, any ideas to get more life out of my chain...
Thanks ;)
Bbqjoe
Banned
Location, Location
Try oiling the next one before it needs it? :D :roflol:
If you're wearing out a chain in 30 miles or so, something ain't right.
I get mine from TSC. Never had a problem.
Since they're exposed chains (unlike the closed-off, enclosed, constantly-lubed timing chain on my car for instance), they tend to wear out relatively quickly being exposed to dirt and grit.
Maintenance-minded people know this and in the past, when constantly replacing parts was cost prohibitive, they maintained the chain (motorcyclists, mainly). They took it off, cleaned it, re-lubed it and replaced it back on the bike and they did that at routine intervals.
Heck, the go kart racers do this as well. Probably after every race.
A soak in heavy weight gear oil is probably the best way to lube, lazy arse. :rolleyes:
anickode
S.E. Michigan
a lubricant that doesn't just sling off would be better too. There are aerosol chain lubricants that tack a little bit and stay put.
I use Tri-Flow. I know that's my answer for everything, but it is really good stuff, especially if you lube the chain and give it time to soak in before you take off.
It does sound however, like you might have some tension and/or alignment issues. Or is your sprocket so big it contacts the ground on rough terrain?
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Maybe the problem is that it says China on every link IDK :D... It has the correct tension and alignment I think... And it also has a skid plate..
I has thinking of making an oil dripper like the ones they have on motorcycles..... I ride sleds so I'm use to just Putting gas in and go!!
Is Tri-Flow an aerosol lubricant?
In my experience, you don't want that for chains...but most of the time, that's what is sold.
I guess the manufacturers know their product is going to go everywhere, and sometimes on the intended surface, but that's a good way to keep their stuff flying off the shelf--> WASTE. :cool:
Soaking is the only way to get lube properly into all the nooks, crannies and crevices of the chain.
anickode
S.E. Michigan
It's available in aerosol or a bottle. It penetrates really well - Some pretty impressive capillary action. And it clings quite well. There is a foaming version as well.
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
:oops::roflol: just fell off...
I have 8 feet a Chinese chain in the shop, I wanna try too use it without wearing it out so fast.
Lube it with WD-40 and then bury the chain in sand before using. Should work a treat. :thumbsup:
Don't forget your Adderall®.
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Tried it already :D
Would this be a retarded idea, if I some how fabricated a chain case for the chain so the chain is sealed from the dust and the chain take's a bath in oil all day IDK...
---------- Post added at 06:31 PM ---------- Previous post was at 06:27 PM ----------
:idea2: I have another idea... What if a replaced the chain with a belt? Which one sounds more possible...
IDK maby I should just snort some more Adderall :D
They have cogged Kevlar drive belts for motorcycles... Needs no maintenance.
Concession karts use a belt final drive, also cogged or toothed....
Even have those for bicycles, albeit not widespread.
anickode
S.E. Michigan
Get a stone kick up and run between the belt and the belt cog, and you'd be in no better shape than with a chain.
Gotta be a reason those belts are used on road bikes, concession karts, and cruisers, and not on mountain bikes, dirt bikes, and buggies.
Since you already have a chain guard, why not get some sheet metal and rivet on there to make the guard wider?
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Ya maybe I'll seal it up real good and add a motorcycle oil dripper... Or I could add a belt and seal it up real well..
Bbqjoe
Banned
Location, Location
How about just getting better chain?
I have every bit as much dust and sand as you do.
Maybe you're keeping your chain too tight. There's supposed to be a little slop in it. Like a half inch or so.
Constantly trying to keep it tight will wear it out real quick.
MTNSleder
😈 Snake ƘƖԼԼЄ&
USA/CANADA
Lookie what I found a cute little belt pulley! Well now you know which option I'm going to do...
I have no idea where you're going with that, and I don't care.
Thanks for the unneeded thread on "Chain Lube" though. Not like the forum hasn't covered that before ad infinitum. :rolleyes:
All in a day's work though, huh? :popcorn:
