Chain Loose in some spots and tight in others?
rgvkid
Charlie Don't Surf!
Los Angeles, Anaheim
Its a fairly new chain only has about 2 hours on it. It has about 5/8 inch play in but in one spot it tightens up pretty taught. Is this normal?
The Sproket and clutch are aligned up fine.
the-cyborg
Spring, Texas
Sounds like your rear sprocket is not perfectly round, or miss aligned on the hub, and/or if it is on a live axle you could have a bent axle.
I vote bent shaft. Take chain off, and spin shafts by hand keeping a close eye on it. You may have to clamp something very close to the edge of the sprocket and watch the gap as it turns.
machinist@large
West Michigan, 49331
:iagree:50/50 on the shaft itself; sprocket may have one area bent (folded over) over. Sideswiping/ landing on something solid could do it.:oops: :thumbsup::sifone:
Wim
Jazz Maverick
Oz
as above.
also, take chain off and check the links, any stiff/jammed? ...could be stretched in one place?
