MikeinMadison
- Messages
- 42
- Reaction score
- 1
Thanks for any help!
This problem has been maddening, and I haven't found the issue discussed anywhere.
Got a good deal on an older Manco kart and decided to put my 9hp Robin on it, at least for a while. I cut off the existing engine mount and welded a new one on so the clutch would line up with the sprocket. It's a little one-wheel-drive kart. I bought a Comet clutch that gokartsusa said could handle the 9hp+ that the motor puts out. New #35 chain. Everything lined up well. New #35 chain 12 tooth clutch, #35 60 tooth sprocket, and on its maiden voyage: POP POP POP... The chain sounded like it was jumping teeth somewhere. Most pronounced when starting out, or when accelerating. The chain was a little on the tight side, so I was surprised, but the wheel sprocket was worn, and with the little tires, top speed was 22mph... so I bought a new 42 tooth sprocket.
Same problem, and I saw what is happening by keeping the kart from moving and giving it a little gas until the clutch sprocket just starts to turn. The chain rises up off the top of the clutch sprocket and jumps ahead. If the chain it really tight, it happens less.
What I've done: checked chain links -- all are good/flexible, adjusted chain tension -- from a little tight to a little too loose, removed rubber engine mounts so motor is stiffly mounted, checked and rechecked alignment between sprockets, checked teeth on clutch sprocket -- all appear symmetrical/consistent.
I don't know what else to do... New chain, clutch, and sprocket... What gives? Thanks again for any help!!!
